ILIAS_g_183177
Mar 10, 2016HTTP monitor check
Hello,
I would like to ask how and if it feasible to run a GET from a Linux server and forward the result to the ltm monitor check. In other words, the ltm monitor health will log in (ssh) to the servers and run the command "GET http://www.google.com" and retrieve the HTTP result (200 OK, 503, etc). If ltm monitor health check receives "HTTP 200", then pool member is UP. If check takes other than "HTTP 200 OK", then moves the service to the other node. The pool members of the virtual server will act active-standby.
thank you.
