HTTP Health Monitor Receive String issue
I am currently having an issue with the Receive string part or a HTTP health monitor. I am using a GET request like: GET /default.aspx HTTP/1.1\r\nHost: myurl.com\r\n
I am also using authentication which seems to work fine. What i want is to check the HTML for something like 'hello' within the title/body or whatever. The monitor works as when i input 200 ok - the pool appears as up. Also, the Receieve String does not.
Does anyone have a working example of a receive string that looks for a match within the body rather than just the Header or simple HTML tags?
- What_Lies_Bene1
The receive string formatting is very flexible, just enter the string you're looking for as it appears in the response. For instance: Look For This String. It is case sensitive.
- Chris1269_13050
I have tried that - could it be something to do with encoding? F5 redirects to HTTPS. Will this require a HTTPS health monitor instead? The only thing i can really get working is 200 OK.
Please note that when the website is first launched a login box appears right away in which i assume credentials i specified when creating a HTTP Health monitor are passed through ok. (Within the username and password section)
Anyhelp or a working example of a receieve string would be greatly appreciated.
- What_Lies_Bene1
OK, is the traffic between the F5 and server(s) SSL or plain HTTP?
Any string should work, there's nothing special about it at all. I'd suggest you do a packet capture server-side to actual confirm what comes back from the server in response to the monitor and also confirm the authentication works. Can you do that?
- Chris1269_13050
Thanks, this issue has now been resolved. I needed to add User-Agent to the request.
- Gerlan_32355
Altostratus
I inserted the User-Agent on request and worked well, too! Thanks for help! Follow the example of request: GET /system1/ HTTP/1.1\r\nHost: host1.mydomain.com\r\nUser-Agent: Mozilla/4.0 (Compatible; MSIE 6.0; Windows NT 5.0; T312461)\r\nConnection: Close\r\n\r\n Receive string: SystemOK- Aaron_F
Ran into new use for this information. New Tomcat server deployments are returning HTTP 200 responses when sending CURL requests from the F5, but when using a basic HTTP health monitor, it was getting HTTP 500 response, resulting in failed health check. Turns out that new Tomcat web server versions are requiring User-Agent: be defined in the health monitor call from the F5 to the tomcat web servers running new software.
- What_Lies_Bene1
Ah, OK. I'll keep that in mind myself. Thanks for letting us know.
- ckane_16382
Can you share your actual SEND and RECEIVE strings (sanitized as needed). I'm trying to accomplish the same thing in that I'm looking for "ok" in the RECEIVE string text. I'm not interested in what's in the header. My application owner intends to run his own downstream tests and provide me with either ok or notok. I only care to match on the text ok. I can't get anything to work. I've tried every combination of regular expression matching for ASCII and HEX, quotes, no quotes, \r\n, no \r\n....can't get anything to work. If I use Fiddler I see the raw response is ok.
- Peter_Z
Cirrus
You should look for the string that is unique and different when the 'good' and 'bad' response is received. Note if your server returns ok or notok and you will set receive string to ok, you will have a match in both cases as the 'ok' string is present in both responses - so the member will stay UP even when it returns notok.
- Chris1269_13050
I have managed to fix the issue by simply adding the required user agent to the string! Hope this helps
- karimbruxelles1
Hi Ketzuken,
Any example for the send/recieve. Share with us Please
thanks
