splendid81_2675
Aug 16, 2016HTTP header insertion using irules
Need some help here, I am trying to insert a http header with value of another header in the same HTTP request, how do I do that?
E.g.
when HTTP_REQUEST { HTTP::header insert "User-Agent" [reference to another header value] }
- Vijay_E
Cirrus
Try this:
when HTTP_REQUEST { if { not (HTTP::header values eq "") } { set VALUE [HTTP::header values ] HTTP::header insert "User-Agent" $VALUE } Hi Splendid81,
you may use the iRule code below...
when HTTP_REQUEST { if { [HTTP::header values ""] ne "" } then { HTTP::header remove "" HTTP::header replace "" [HTTP::header values ""] } }Note: You may uncomment the HTTP::header remove "" line if security is a concern for you. Otherwise LTM will just replace/add a single occourence without checking if the same header name exist more than once.
Cheers, Kai
