puluck's avatar
puluck
Icon for Cirrus rankCirrus
Jan 22, 2014
Http connection reset
Hi all,
I am facing one issue where clinet XML data is send to server via loadbalncer and after 5 Min connection being reset by loadbalancer .Application team have tested this several time and it always 5 min.
We have very less time to resolve this issue .If some one can help us will be great
  • I believe 5 minutes is the default idle timeout for TCP profiles. You can adjust the idle timeout on the TCP profile attached to your virtual server to something higher than 5 minutes, or lower your keep alive interval to ensure the connection stays open.
