Ozzy's avatar
Ozzy
1 year ago
Http / https health monitor issue
I tried to create https health monitor , but it is not worked
curl -v https://d-p-m-d.bms.rome.com:10221/login
StatusCode        : 200
StatusDescription :
Content           : <!DOCTYPE html>
                    <html xmlns="http://www.w3.org/1999/xhtml"
                    <link rel="stylesheet" href="css/material-components-web-3.0.0.min.css" />
                    <link rel="stylesheet" href="css/auth-shared.css" />
                    <link rel="...
RawContent        : HTTP/1.1 200
                    Set-Cookie: XSRF-TOKEN=a00fgfhjjffa-efc7-4ahjj9-bahhgf-1099ccgf21ghgcdd2; Path=/; Secure,locale=en; Path=/
                    X-Content-Type-Options: nosniff
                    X-XSS-Protection: 1; mode=block
                    Strict-Transport-Securit...
Forms             : {login-form}
as a send string
GET /login  HTTP/1.1\r\nHost: d-p-m-d.bms.rome.com:10221\r\nConnection: Close\r\n\r\n
receive string
HTTP/1.1 200
  • Teerarat's avatar
    Teerarat
    Service Port should be config on pool member and remove port on Hosrt
    • Ozzy's avatar
      Ozzy
      sorry I do not understand your explanation.
      • as i said before
        use
        GET /login  HTTP/1.1\r\nHost: d-p-m-d.bms.rome.com\r\nConnection: Close\r\n\r\n
        do not use port ":10221" in the monitor
  • Do not include port in string
    try
    as a send string
    if you need to monitor a port different than the one used in pool member, use alias
