Stephen_Peters's avatar
Stephen_Peters
Dec 13, 2013
HP Network Automation Drviers
My HP NA manager only has driver 'F5 (single-config) load-balancers, Big-IP series, OS version 9.4.x - 10.x F5-BIGIP-v9'avialable.. the device i want to manage is running 11.4. Is there a new drvier for this SW version?
  • Hi Stephen,
    I used HPNA in a previous position, and device drivers should not come from the vendor but from HP. You can also use NDS (if I remember well the name) to write your own custom HPNA driver if you need to grab some very specific data.
    Anyway, I did introduce some RFE to HP at that time, and if you come with detailled examples they are able to release a new driver quite quickly.
    hope this helps
    Benoit
  • you are welcome.
    You can always try to give a shot with the drivers for 9.x/10.x but there has been some 'big' changes in v11.x, so I cannot guarantee that results will be as expected.
    Best regards,
  • The commnds used unsder the 9.x 10.x Driver are no longer supported, so it returns lots over errors..
