mayur_m_150368
Apr 16, 2014How we can publish multiple applications on same VIP with same port & same irule?
We have recently procured F5 device for Reverse proxy. We are now migrating ISA applications but while migration we are facing issue.
I need help to create irule as per our requirement.
If we have ...
Kevin_Stewart
Employee
Apr 18, 2014Try this:
switch [string tolower [HTTP::host]] {
"abc.com" {
if { [string tolower [HTTP::uri]] contains "cvapweb" } {
pool abc_9090
pool abc_8080
"xyz.com" {
pool xyz_9090
pool xyz_8080
Not sure why you're using SSL::disable in your original iRule. Using it in an HTTP_REQUEST (OSI layer 7) suggests that you want to disable server side SSL, but if none of the downstream pools are SSL, and you don't have an SSL profile applied to the VIP, then you don't need this command.
