mayur_m_150368
Apr 16, 2014How we can publish multiple applications on same VIP with same port & same irule?
We have recently procured F5 device for Reverse proxy. We are now migrating ISA applications but while migration we are facing issue.
I need help to create irule as per our requirement.
If we have ...
Cory_50405
Noctilucent
Apr 16, 2014Try this:
SSL::disable
if { [string tolower [HTTP::host]] equals "abc.com" } {
if { [string tolower[HTTP::uri]] contains "cvapweb" } {
pool abc_9090
else {
pool abc_8080
elseif { [string tolower [HTTP::host]] equals "xyz.com" } {
if { [string tolower [HTTP::uri]] contains "cvapweb" } {
pool xyz_9090
else {
pool xyz_9090
mayur_m_150368
Apr 17, 2014Hi,
I can able to save this irule in F5, but when i can try to access the URL's through F5 its not working, it only goes till https (security page) but cant go beyond that. It menas it cant pass through irule. I can able to see hits on virtual servers but it not comes in pools. The same application is running through microsoft ISA server.
