mayur_m_150368
Apr 16, 2014How we can publish multiple applications on same VIP with same port & same irule?
We have recently procured F5 device for Reverse proxy. We are now migrating ISA applications but while migration we are facing issue.
I need help to create irule as per our requirement.
If we have ...
Cory_50405
Noctilucent
Apr 16, 2014You should also be doing a 'string tolower' on your HTTP::uri match, same as you're doing on your HTTP::host match. And there's no need for the 'then' after your if statements.
If after you make these changes and the iRule still doesn't work, please describe exactly what isn't working.
mayur_m_150368
Apr 16, 2014Hi thanks for reply, but i tried with removing then still it waa not working. Actually i have just tried this was per our requirement but not sure wether such irule will work or not. When i tried to create with same irule it was showing number of errors. Can u plz suggest any one as per our scenario. How i can write it?
