mayur_m_150368
Apr 16, 2014How we can publish multiple applications on same VIP with same port & same irule?
We have recently procured F5 device for Reverse proxy. We are now migrating ISA applications but while migration we are facing issue.
I need help to create irule as per our requirement.
If we have ...
mayur_m_150368
Apr 16, 2014Need to clear points,
If we have “abc.com” & “xyz.com” two url’s those are published through F5 on 443 port with same VIP. Case 1:- If any request hits to virtual IP it should redirect to 8080 & Case 2:- If ‘/document’ & ‘/CVwebap’ comes in URL it should route to 9090.
For such scenario we have 2 separate pools for both application.
1.Abc_8080 ---------- This is default pool for “abc.com”
2.Abc_9090 ----------- if “abc.com/documents” & “abc.com/cvwebap” it should come to this pool
3.Xyz_8080 ------------ This is default pool for “xyz.com”
4.Xyz_9090 ------------ if “xyz.com/documents”& “xyz.com/cvwebap” it should come to this pool.
I have created below irule, but it is not working, Can anyone help me to resolve it?
SSL::disable
if { [string tolower [HTTP::host]] equals "abc.com" } then
{ if { [HTTP::uri] contains "cvapweb" } {
pool abc_9090
pool abc_8080
elseif { { [string tolower [HTTP::host]] equals "xyz.com" } then
pool xyz_9090
}else {
pool xyz_9090
