Genna_Reingold's avatar
Genna_Reingold
5 years ago
How to use literals starting with "$" in iRule
I need to pass client certificate to WebSphere so the application can perform SSL based authentication. I following this article https://support.f5.com/csp/article/K95338243
However in WebSphere App Server the headed for client certificate is $WSCC. But if I code iRule like this
  HTTP::header insert $WSCC [b64encode [SSL::cert 0]]
$WSCC is treated as a variable WCSS and the rule is broken
How do I get around this issue?
Genna
  • Hi Genna,
    you can escape the '$' character with a '\'. This should work:
        HTTP::header insert "\$WSSC" [b64encode [SSL::cert 0]]
    KR
    Daniel
  • to prevent variable substitution, you can replace double quotes by curly braces.
        HTTP::header insert {$WSSC} [b64encode [SSL::cert 0]]
    Stan
