how to test for disable SSLv3 for vulnerability
We have a vip running on port 443 (clientssl) in bigp IP version 10.2.3. we turn off SSlv3 due to vulnerability. we change ciphers to DEFAULT:!SSLv3 in this SSLclient profile (not global clientssl profile). my question is how do we test SSLv3 is disable? after doing the research, I run this command in my F5 backend: openssl s_client -connect -ssl3
and got the message: getaddrinfo: Temporary failure in name resolution connect:errno=110
do you have otherway to test it or how to run this command correctly? Thanks for your help
- kash_49328
Do the TCPdump and check it in the wireshark. I believe if you are not allowing sslv3 then Big ip should not allow the V3 hellos. Fyi 10.xx may be allowing SSLv2 also. I had 11.2.1 and it was allowing SSLv2 and v3. tcpdump -nni 0.0:nnn -s0 '(host xxxxxxx ) and port 443 or xxxx ' -w /var/tmp/xxxxxxx .pcap
- truongh_36312
it workss, thanks a lot for all yours info and instruction.
- shaggy
curl is also an option. the -3 flag forces an SSLv3 handshake
curl -kvv3 https://www.xyj.gov.au
