SaranSakthivel's avatar
SaranSakthivel
7 years ago
How to Sync F5 configuration using Python SDK
I tried the following to sync the config.
mgmt.tm.sys.configsync.synchronize_to_group_v2('SYNC-FAILOVER','/Common/test-host.com')
The idea is to 'sync' and also optionally to do a 'force sync'
  • I was able to initiate config sync using bigsuds, anyone knwos hows to initiate config sync using f5 python SDK ?
    b.System.ConfigSync.synchronize_to_group_v2('SYNC-FAILOVER','/Common/', 'true')
  • After some more more reading of f5 python sdk docs, I was able to get it working. Kindly let me know if there is a better way of doing it.
    For Force Push
    mgmt.tm.cm.exec_cmd('run', utilCmdArgs='config-sync force-full-load-push to-group ')
    For Push
    mgmt.tm.cm.exec_cmd('run', utilCmdArgs='config-sync to-group ')
    • SaranSakthivel's avatar
      SaranSakthivel
      Is there a way to get a feedback of whether the Sync was successful or not in one go ?
      Currently I have to run the above command and run another command to check for sync status.
