Parveez_70209's avatar
Parveez_70209
Dec 12, 2013
How to Switch Between Pools using Irule
Original Irule:
when HTTP_REQUEST { set http_uri [string tolower [HTTP::uri]]
if {$http_uri equals "/" } { HTTP::redirect "https://kepogstest.jdadelivers.com/ikb" pool kepogstest.example.com-POOL return }
Now one option of the application called floorplan is served by another server, so based on that we created a second pool named as : kepogstest.example.com-Floorplan-POOL.
Kindly assist in editing the Irule which will include the new created pool.
Thanks and Regards Parveez
  • I don't get why you send an HTTP::redirect to the client, but also send to the pool at the same time ? Usually, when you send to a pool member, you don't send and HTTP redirect at the same time. But i am probably missing something here. Anyhow, what you are looking for should be like this (replace /floorplan by what is required in term of URI for your application, same for your redirect):
                 return
            elseif {$http_uri equals "/Floorplan" } {
                 HTTP::redirect "https://kepogstest.jdadelivers.com/Floorplan"
                 pool kepogstest.example.com-Floorplan-POOL
                 return
  • Philou, I think your second condition may cause an infinite loop. If URI equals /floorplan, go to /floorplan. This issue, Parveez, is a matter of state. As Philou alludes, when a client makes a request (ingress) and the iRule responds with a redirect (egress), there is no further ingress and no traffic will get sent to a pool. Something like this may work instead:
        if { $http_uri equals "/" } {
        } elseif { $http_uri starts_with "/ikb" } {
