siddhesh_137522's avatar
siddhesh_137522
Feb 14, 2014
How to rewrite HTTP payload using Irule
Hello Team,
I have simple requirement that i need to rewrite HTTP payload whenever a request if genrated for opening a document.
For ex:- The below link and chracter which is made bold shoudl be replaced when request land on server https://abc.com/xyz/123xcv/1401300147/InfoView/listing/main.do?service=/common/appService.do&appKind=InfoView&isNewWindow=true&newUrl=https%3A%2F%2Fabc.com%2Fxyz%2F123xcv%
I need to replace the trailing https%3A%2F%2Fabc.com% with http://xyz.com:8080/...
I tried above with stream profile but not able to get any sucess..
Helpful if someone can put light on the above rewriting..
Regards Siddhesh
  • Is this URL in the browser address bar, or actually in the HTTP payload? If the latter, request or response?
  • Well, just a hunch here, but guessing you could accomplish this with a stream iRule. Apply a blank stream profile to the VIP and this iRule:
         disable server side compression
        HTTP::header remove Accept-Encoding
         disable stream for requests
        STREAM::disable
    when HTTP_RESPONSE {
         only do this for text-based responses
        if { [HTTP::header Content-Type] contains "text" } {
             establish the stream expression
            STREAM::expression {@https%3A%2F%2Fabc.com@http://xyz.com:8080@}
             enable stream processing
            STREAM::enable
    You may actually need to do this:
    {@https%3A%2F%2Fabc.com@http%3A%2F%2Fxyz.com%3A8080@}
