serge_faller_83's avatar
serge_faller_83
Jun 29, 2005
How to read a data in the UDP payload ?
I would like to use an UDP payload information (not header) to target a specific node. I need to read and handle this data (6 octets).
IP message example : Field "01007d" (radius).
81 66 07 14 00 85 8d a9 01 01 00 7d 26 fc f1 f2 ...
UDP/ 81 66 07 14 00 85 8d a9 /endUDP
radius/ 01 "01 00 7d" 26 fc f1 f2 ...
How can I select this data ? (set info [UDP::payload] xxx] ?)
Does anybody have an example ?
Thanks for help.
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    This should help get you there:
    when RULE_INIT {
       set ::radius_signature [binary format c3 {1 0 0x7d}]
    when CLIENT_DATA {
       if { [UDP::payload length] > 4 } {
          binary scan [UDP::payload] x1c3 radius_stuff
          if { $radius_stuff == $::radius_signature } {
             node a.b.c.d 123
    Disclaimer: I have not tested if this rule even loads.
    You will likely also want to enable "datagram lb" so that each udp datagram is re-loadbalanced.
  • Thanks for the irule and your reactivity !
    The data I should retrieve in a payload is a radius Type/Length/Value attribute (variable position). So I must test several data.
    I have some questions for confirmation (... It's my first use):
    example . Radius/UDP Ethereal
    UDP / 69 51 81 66 07 14 00 85 8d a9 /end UDP
    begin Radius / 01 01 00 7d 26 ...
    Are the following lines correct?
    - To load the first 50 octets (for example) bytes of the payload
    When CLIENT_ACCEPTED { UDP::collect 50 }
    - If I want to read Radius Lenght : 007d (?)
    binary scan [UDP::payload] x2a4 Radius_Lengh
    Thank you for your assistance .
    unRuleY_95363
    Historic F5 Account
    Yes, your assumptions are correct. "UDP::collect 50" collects the first 50 octets of the payload (not including the IP/UDP headers).
    For the binary scan, I would probably use "I" for the radius length since it is a 4 byte integer stored in big-endian format that you want.
    So, try this:
    binary scan [UDP::payload] x2I1 Radius_Length
    unRuleY_95363
    Historic F5 Account
    Woops. I just re-read your post and it looks like radius length is really only two bytes so you'll want to use "S" instead:
    binary scan [UDP::payload] x2S1 Radius_Length
  • thanks for the answers,
    I have 2 problems :
    - procedure UDP::collect undefined
    01070151:3: Rule [Irules_Radius_acces] error:
    line 12: [undefined procedure: UDP::collect] [UDP::collect 50]
    - When I look at result of UDP::Payload command, I dont see a HEX sequence.
    ex : "binary scan [UDP::payload] a10 Radius_zone"
    give Radius_zone = ^A^O\300\200^T\303\217 \303\234^X^Da
    but this text would have to be read = 0101007d26fc in HEX ...
  • drteeth_127330's avatar
    drteeth_127330
    Historic F5 Account
    UDP::collect is undefined. Since UDP does not guarantee ordering, collecting doesn't make much sense. Use UDP::payload instead. I'm not sure I completely understand your second issue, but you can use the binary format command to convert the binary data to a hex string.
    unRuleY_95363
    Historic F5 Account
    What you are seeing is merely the ascii equivalent of your binary data (as I assume you might have logged it). Follow Dr.Teeth's suggestion of using binary format if you would actually like to see the values in HEX. Probably something like:
    log "Packet rcvd: [binary format h* [UDP::payload]]"
