eetech2008_5405
Apr 10, 2009how to inspect https request in Irule, beginner needs help
hi, I would like to write an Irule to check for cross-site-scripting by filtering keywords such as "
- dennypayne
Employee
You'll need to use a clientssl profile (and possibly a serverssl profile - if you don't want to reconfigure the servers to listen on port 80 instead of 443) on your virtual as detailed in the Configuration Guide here:
https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/LTM_config_guide_943/ltm_ssl_profiles.html1302217 (Click here)
Denny
