Nicolas_MENOUX_
Dec 04, 2007How to insert " (double-quote) into stream target ?
I would like to know if it is possible to insert double-quote character into the Target value within a stream profile. As mentioned by the GUI ,double-quote character is forbidden. So, by editing the bigip.conf is there any syntax to "cheat" and insert the forbidden double-quote and then re b load the conf ?
Thanks for your help,
Regards,
Nicolas
- hoolio
Hi Nicolas,
I'm guessing if the GUI validation prevents it, there is a reason. You might try wrapping adding a default stream profile and then specifying the source and/or target in an iRule. You should be able to use curly braces {} in a rule to do this.
Btw, did you figure out what the error was with the stream expression after upgrading to 9.3?
Aaron - Nicolas_MENOUX_
Hi aaron,
I've tried with a "" directly into the bigip.conf and it seems to work for only one block (ie : @xxx@yy@) when I try to add a second "" in a second bloc after the first one, there is a parsing error during b-loading.
Regarding my previous post, I still do not have an answer to that weird issue ...that is why I try an alternative way desperately...
Regards,
Nicolas - Patrick_Chang_7Historic F5 Accountwould %34 work for you?
