How to Force Failover to Second Node
I have a VIP with an irule that reads the destination port and forwards the traffic to the appropriate pool. if the traffice is going to port 80 then use pool1, if traffic is going to 8081, then use pool2 and if the traffic is going to 873, use pool3. All three pools have node1 and node2 as members. In pool1 both nodes are monitored with a custom monitor that looks at a html file that returns a text string.
What I need is a way to failover node1 to node2 in all pools when the custom monitor marks the node1 down.
Any ideas would be great.
- JG
Cumulonimbus
An external monitor can be used to monitor anything, and does not have to monitor the pool member it is attached to. In other words, you can apply a monitor for pool2 and pool3 that actually does the same thing as the monitor for pool1; you may actually be able to use the same monitor of pool1, depending on how you script it.
- StephanManthey
Nacreous
You may also create port specific monitors (alias port definition) and assign them on node level. By default the 'availability requirements' is set to 'all'. So if one monitor fails, the node will be marked down. The node acts as parent object in all pools and you will observe a failover to node.
[root@bigip_a11:Active:Disconnected] config tmsh modify cli global-settings service number [root@bigip_a11:Active:Disconnected] config tmsh list ltm monitor http monitor_port_80 ltm monitor http monitor_port_80 { defaults-from http destination *:80 interval 5 send "GET /\\r\\n" time-until-up 0 timeout 16 } [root@bigip_a11:Active:Disconnected] config tmsh list ltm monitor http monitor_port_8081 ltm monitor http monitor_port_8081 { defaults-from http destination *:8081 interval 5 send "GET /\\r\\n" time-until-up 0 timeout 16 } [root@bigip_a11:Active:Disconnected] config tmsh list ltm monitor http monitor_port_873 ltm monitor http monitor_port_873 { defaults-from http destination *:873 interval 5 send "GET /\\r\\n" time-until-up 0 timeout 16 } [root@bigip_a11:Active:Disconnected] config tmsh list ltm node node25 ltm node node25 { address 10.131.131.25 monitor monitor_port_80 and monitor_port_8081 and monitor_port_873 session monitor-enabled state checking }Are you looking for a pure HA setup?
I.e. all traffic is generally balanced to one node only, sticks there and reselection only applies if it fails and from now everything should stick to the alternative node? In this case you can use priorities and combine it with 'destination address affinity'. Even if this sounds a bit odd, but it works fine. The persistence table will show a single entry with target of virtual IP and selected poolmember. In case of reselection this single entry changes accordingly. - wesweber_98132
The HA is only for the nodes. I can add a pre-defined http monitor to a node, but can I add a custom monitor that looks for output from a URI on port 80 to a node? Haven't been able to do that in the GUI.
- wesweber_98132
After playing with this all day, I've made no progress. The docs say you can create a custom monitor and apply to a node. Then if the node is in mulitple pools and the monitor marks the node as down, it's show as down in all the pools. The monitor I created is a http type and is doing a GET /rotation.html\r\n and looking for a text string, "PONG!". The monitor is in the same partition as the node. When I try to add the monitor to the node it's not in the list, the list only contains what looks like default monitors in the common partition. This is all being done in the GUI. So do I need to do this from the cli like the second reponse to the initial post implies?
- JG
Cumulonimbus
Can't tell if the monitor is really not applied. But did you test your monitor with a command line tool, such as curl or telnet? Some Web servers will not work if protocol version is missing. So the send string should be "GET /rotation.html HTTP/1.0\r\n\r\n" instead. Apply this on the pool level first and edit the file to make sure it works at all.
- Kevin_Stewart
Employee
+1 for Stephen's answer. When you create the monitor you must give it an alias port to be able to use it at the node level. The condition of the the monitor for that node will therefore affect every pool that the node is in.
