Steven_J__Willi
Sep 05, 2014How to find a pool reference within F5 irules
trying to remove a pool after the removal of a VIP, get an error:
The pool is referenced by one or more HTTP Class profiles.
How can I figure out where the references are?
- Kevin_Stewart
Employee
At a minimum you could search through the GUI under the HTTP classes section to find which classes are referencing the pool. Alternatively you could search through the /config/bigip.conf for any mention of the pool and where it's referenced.
- shaggy
If it's referenced by an HTTP class profile, the following TMSH command will do the trick:
list ltm profile httpclass one-line | grep
