How to establish communication in between two internal isolated LAN's
Hello Experts,
Would need your some experts comment on my below requirement
Current VLAN setup
12.x.x.xExternal Public VLAN
172.x.x.xInternal Private VLAN
192.x.x.xF5 Management VLAN
10.x.x.xSNMP VLAN
Already working traffic
- Inbound & outbound (DNS lookup) working in between Internal & External VLAN’s
- Management working privately
- SNMP VLAN configured F5 with SELF IP (floating & non-floating) & able to ping trap manger server
Requirement
Would need to establish outbound connectivity from Internal to SNMP VLAN
My SNMP Trap Manager server located in SNMP VLAN & now requirement is the TRAPs generated by any server located in Internal Private VLAN will send it to Trap Manger server, since snmp & internal both are isolated LAN no communication in between though would need some expert comments about how we establish route in between Internal LAN outbound SNMP trap traffic towards SNMP_VLAN
Thanks in advance for your advice
Best Regards,
Sumit
- Cory_50405
Noctilucent
A forwarding virtual server on the LTM should work for you. You can set it up to listen on your internal vlan and only allow certain sources. Read more about it here:
http://support.f5.com/kb/en-us/solutions/public/7000/500/sol7595.html
- Sumit_Tyagi_121
Thanks for sharing this info, will try to implement the same as per the link provided if there any issue will revert back
Thanks again...
With Regards,
Sumit
