How to Deploy GTM for DR site failover
Dear Guys, How to Deploy GTM for DR site failover
- Kevin_Davies_40
Nacreous
There are a number of ways to deploy GTM for DR environments but without more information there is very little we can suggest.
- pkinhyd1986_152
Requirement is for diverting few Internet application traffic to DR site when Head Office failed
- Chris_Akker_129Historic F5 Account
Hi Pkin, there are numerous examples of how to do this, for a variety of applications. You probably need to be much more specific to gather a detailed response.
But, just for grins, if your application is Oracle based, we do have a very nice whitepaper co-written by Oracle and F5 that tells you everything you need to know in one document. Check it out here:
http://www.oracle.com/technetwork/database/availability/oms-dr-f5-big-ip-gtm-1880830.pdf
-Chris.
- Kevin_Davies_40
Nacreous
Setup two GTM's internet facing, one at each site.
Configure a subdomain to delegate to the GTM. Change your application's DNS record to a CNAME of a new wideip address on your GTM. Create a pool with both application virtual servers, set the order so the normal server is always first by using Global availability. Assign that pool to your wideip.
DNS delegation wip.mycompany.com in NS gtm1.mycompany.com. wip.mucompany.com in NS gtm2.mycompany.com. gtm1.mycompany.com in A X.X.X.X gtm2.mycompany.com in A Y.Y.Y.Y DNS mapping myapp.mycompany.com in CNAME myapp.wip.mycompany.com. WideIP Configuration myapp.wip.mycompany.com pool myapppool virtual myapp.mycompany.com virtual dr_myapp.mycompany.com Server Configuration Server primary_myapp.mycompany.com X.X.X.X Data Centre Primary Virtual myapp.mycompany.com X.X.X.X Server dr_myapp.mycompany.com Y.Y.Y.Y Data Centre DR Virtual dr_myapp.mycompany.com Y.Y.Y.Y Data Centre Configuration Name Primary Name DRYou will need to add some health checks suitable for your environment. See askf5.com GTM monitors for details. If your application are hosted on BIGIP LTM's the GTM's can talk to them to discover the virtual's so you do not need to add them manually.
When you make a request to myapp.mycompany.com the DNS will pickup the domain delegation and ask GTM to resolve the name. GTM will check if your primary site is up and return the address of that application server X.X.X.X. If the application server at that site is down it will return the DR site Y.Y.Y.Y
