MrRichard's avatar
MrRichard
Aug 13, 2013
How to create iRule to deliver an alternate page response other than 'page unavailable'
When we currently disable one of the virtual servers in our setup, we get an 'unable to display this page' message in the browser. Rather than this, we would like to display a maintenance page so that users are made aware that there is an issue. We had thought of implementing this as an irule (and have created one), but it does not seem to be working. We have the following code:
  set hostvar [HTTP::host]
  set urivar [HTTP::uri]
when HTTP_RESPONSE {
  if { [HTTP::status] eq "404" } {
    HTTP::respond 200 content {
      The site ($hostvar$urivar) is currently down for essential maintenance.
    } Cache-Control No-Cache Pragma No-Cache
We hoped that by just creating an irule that this would be fired when a virtual site was disabled - but this isn't the case. We have tried adding the irule to the resources area of the virtual server, but it still does not display the message. As a result, we're not sure what we're doing wrong and need some assistance to get this working. For a start, the code parses correctly, but does this code look reasonable to what we need to achieve? Finally, how do we get the irule to fire?
Another option was to just redirect to a different web server and page. We tried the following, but again, it didn't seem to work.
when LB_FAILED { if { [active_members [LB::server pool]] < 1 } { HTTP::fallback "http://internalsite.co.uk/slp/maintenance.html" } }
So we're just after some advice as to what would be the best way to go about this - if we've made any mistakes in the creation of the irules, or if there is a better way of implementing what we are trying to do?
    • MrRichard's avatar
      MrRichard
      Thanks Andres, I see where I am going wrong now. :)
  • nathe's avatar
    nathe
    Richard,
    Might a Fallback Host entry set as "http://internalsite.co.uk/slp/maintenance.html" in a HTTP Profile on the VIP work for you? Also, do you disable the VIP itself or the pool member(s) within?
    Hope this helps, N
  • Here's what we use on our public web sites. Stored the HTML and images in iFiles for use elsewhere.
       if {[active_members [LB::server pool]] < 1} {
          switch [HTTP::uri] {
             "/guardian_header.jpg" { HTTP::respond 200 content [ifile get "guardian_header_jpg"] }
             "/guardian_logo.jpg" { HTTP::respond 200 content [ifile get "guardian_logo_jpg"] }
             default { HTTP::respond 200 content [ifile get "maint_index_html"] }
      MrRichard
      Great thanks Dan. I've not used iFiles yet, so I may look to doing this if all else fails. Cheers :)
    • Dan_Cox_24281's avatar
      Dan_Cox_24281
      I like going the iFile route mainly because our web developers here insist on writing their own maintenance page and they require background images, logos, and such. With iFiles I don't have to convert them to base64 and embed them in an iRule. But, if you don't need to serve up any images or large HTML files it would be simpler to just put the HTML directly in the iRule as suggested by Kevin below.
  • The problem is that you're disabling the virtual server. A disabled VIP isn't going to respond to any requests or evaluate any iRule events. A simple alternative would be to disable the pool members and use an active_member check in the CLIENT_ACCEPTED event.
  • When you disable the virtual server the F5 no longer responds on that IP/port, so no iRules will be triggered. I think that you want to disable the servers in the pools instead of the F5 virtual server instead. If all of the pool member servers are disabled, either manually or due to failing health monitors and an HTTP request comes in, a LB_FAILED event will be triggered and you can craft your response. I recommend something simpler, this is the basics of what we use, where your can add your own html, you could also do a HTTP::redirect instead. Remember that the virtual server will need to have an HTTP profile.
    when LB_FAILED { log local0.info "LoadBalanceFailureHost [HTTP::host]" HTTP::respond 500 content { Put your HTML here. } }
  • Thanks all , very much for your ideas and help. This is such a good forum, I was not expecting anything back for a while, so really pleased. Looks like I can work this out now, but I'll post back if I need any more help. Thanks again
  • Arie's avatar
    Arie
    One big problem I see with the various options above is that they use the Status Code 200, which signifies "OK". Since the situation is not OK the proper code should be issued, for instance:
    HTTP::respond 404 content "html maintenance page..."
    See section 10 of RFC 2616 for a list of proper Status Codes.
  • Andres_4712's avatar
    Andres_4712
    Historic F5 Account
    Dont want to be tricky, but RFC actually states the Oposite. 404 is given when "The server has not found anything matching the Request-URI. No indication is given of whether the condition is temporary or permanent."
    "..10.4.5 404 Not Found
    The server has not found anything matching the Request-URI. No indication is given of whether the condition is temporary or permanent. The 410 (Gone) status code SHOULD be used if the server knows, through some internally configurable mechanism, that an old resource is permanently unavailable and has no forwarding address. This status code is commonly used when the server does not wish to reveal exactly why the request has been refused, or when no other response is applicable."
  • For what it's worth we use a 503 (Service Unavailable) from LB_FAILED;-
    when LB_FAILED {
        HTTP::respond 503 Content [b64decode [class lookup $sorry dg_content]] noserver Content-Type "text/html" Retry-After "600" Content-Encoding "gzip" Connection "close"
        return
    We have the HTML gzipped, b64-encoded, and stored in a data group (dg_content). The Retry-After header is for SEO.
    • IheartF5_45022's avatar
      IheartF5_45022
      Sorry just realised this question was about 404s, not when servers down. Ignore :-)
