James_W_'s avatar
James_W_
Feb 20, 2021
How to create external ltm monitor through tmsh
I am trying to create an external ltm monitor through tmsh but I receive the following error when using this command:
tmsh create ltm monitor external somemonitorname - Gives me error "Monitor /Common/somemonitorname parent not found"
list ltm monitor external - doesnt give any results
If we assume that I have a custom monitor made from the template here /config/monitors/sample_monitor . How do I import it and make it to work through tmsh?
  • A bit of search & you'll find the article.​
    For more details - https://support.f5.com/csp/article/K13423​
