myLogin_24886
Oct 10, 2007How to Create a empty pool using java?
I wrote following code to create a LBPool but it only works if i have at least one member(s). My application need to create a empty pool and add it to a VirtualServer.
Code segmenet
String[] pool_names = { "TestPool1" };
iControl.LocalLBLBMethod [] lb_methods =
{ iControl.LocalLBLBMethod.LB_METHOD_ROUND_ROBIN };
iControl.CommonIPPortDefinition member =
new iControl.CommonIPPortDefinition();
//member.setAddress("123.89.0.9");
iControl.CommonIPPortDefinition[][]members =
{ { member} };
m_pool.create( pool_names, lb_methods, members );
- Try passing in the member structure with a size of one with the first element null.
String [] pool_names = { "TestPool1" }; iControl.LocalLBLBMethod [] lb_methods = new iControl.LocalLBLBMethod[1]; lb_methods[0] = iControl.LocalLBLBMethod.LB_METHOD_ROUND_ROBIN; iControl.CommonIPPortDefinition [][] members = new iControl.CommonIPPortDefinition[1][0]; m_pool.create(pool_names, lb_methods, members);
I've tested this in C and it works fine. I don't have a setup right now to test the java version.
-Joe - Great, glad to help!
-Joe
