Dominic_Dinh's avatar
Dominic_Dinh
Aug 15, 2019
How to Create a empty pool using C#?
I wrote following code to create a LBPool but it only works if i have at least one member(s). My application need to create a empty pool and add it to a VirtualServer.
// Create member
        var members = nodes.Select(t => new CommonIPPortDefinition
          address = t.Address,
          port = t.Port
        }).ToArray();
        var newMembers = new CommonIPPortDefinition[][] { members };
        // Create pool with algorithms
        m_interfaces.LocalLBPool.create(new string[] { name }, new LocalLBLBMethod[] { method }, newMembers);
    Steps to Create Thread Pooling in C#.NET
    static void ProcessWithThreadMethod()
       for (int i = 0; i <= 10; i++)
        Thread obj = new Thread(Process);
        obj.Start();
    static void ProcessWithThreadPoolMethod()
        ThreadPool.QueueUserWorkItem(new WaitCallback(Process));
    using System;
    using System.Threading;
    using System.Diagnostics;
    namespace ThreadPooling
       class Program
        static void Main(string[] args)
          Stopwatch mywatch = new Stopwatch();
          Console.WriteLine("Thread Pool Execution");
          mywatch.Start();
          ProcessWithThreadPoolMethod();
          mywatch.Stop();
          Console.WriteLine("Time consumed by ProcessWithThreadPoolMethod is : " + mywatch.ElapsedTicks.ToString());
          mywatch.Reset();
          Console.WriteLine("Thread Execution");
          mywatch.Start();
          ProcessWithThreadMethod();
          mywatch.Stop();
