Evgeny_Kogan_51
Dec 21, 2006How to control the connections within failover
Hi All !
I would like to know if its possible to write an iRule or iControl, which will control my active connections within failover, and here is an example:
I have BIGIP which is deployed as a Load Balancer for three Firewalls. I am not using Firewall Sandwich, therefore I have a problem to route back connections to a proper Firewall module.
LB(BIGIP)
FW1 ---- FW2 ------ FW3
I need LB to move all active connections only of FW1 to FW2 in case when FW1 goes down.
The FW3 should not get any of connections which were opened to the FW1, all of them should be moved to the FW2 only.
All new connections comming to the LB should be balanced between FW2 and FW3 in a regular basis (round robin).
thanx !
- Colin_Walker_12Historic F5 AccountIt sounds like what you're looking for is a pretty basic load balancing setup using minimum active members and priority groups. I would think this would be sufficient to allow FW2 to take over all traffic incoming if FW1 goes down.
Colin
