whithajess_1787's avatar
whithajess_1787
Dec 21, 2014
How to clear Web acceleration cache?
So I have been trying to clear the web acceleration profile cache on applications and have ended up deleting the profile instead with this command:
DELETE '/mgmt/tm/ltm/profile/web-acceleration/~partion~app.app~optimized-caching_profile'
Can someone please help with the right commands for this?
Also tried to clear all with
DELETE '/mgmt/tm/ltm/profile/web-acceleration/all'
not sure it worked as the only response is null ""
Any references to better documentation or understanding would be greatly appreciated.
  • BinaryCanary_19's avatar
    BinaryCanary_19
    Historic F5 Account
    tmsh delete ltm profile ramcache "profile-name"
    Replace
    profile-name
    with the web-acceleration profile name.
    Note that clearing the cache does not reset the stats. To reset the stats, you need to:
    tmsh reset-stats ltm profile web-acceleration "profile-name"
    It is an unfortunate state of things that the command to clear cache is aimed at "ramcache" and it looks like the command you would use to actually delete a profile as per TMSH conventions, but that is how it is.
