T_Rajneesh's avatar
T_Rajneesh
May 06, 2019
How to block /_async/* and /wls-wsat/* at the F5 Load Balancer for Oracle WebLogic server.
Critical remote code execution vulnerability found in Oracle WebLogic server.
Can you please suggest how to block /_async/* and /wls-wsat/* at the F5 Load Balancer.
Is it possible do it via irule on LTM or any other way.
Thank you
  • Three ways to do it...
    Using 'contains':
        if {{ [string tolower [HTTP::uri]] contains "_async" } || { [string tolower [HTTPS::uri]] contains "wls-wsat" }} {
            drop
    Using 'starts_with'
        if {{ [string tolower [HTTP::uri]] starts_with "/_async" } || { [string tolower [HTTP::uri]] starts_with "/wls-wsat" }} {
            drop
    But the best option is to configure a policy in LTM which has exactly the same options I'm using in the previous iRules and is faster.
    REF - https://devcentral.f5.com/articles/ltm-policy
    KR, Dario.
    • davidfisher's avatar
      davidfisher
      Icon for Cirrus rankCirrus
      is this a good way to use irules to just block a CVE? cant we use asm to do this?
      This irule is creating a problem with the f5 maintenance page irule which we are using.
      I have these irules applied, and the moment I add the one with maintenance page, the connection just starts dropping..
      ### MAINT PAGE IRULE
      if { [active_members XXX_pool] == 0 }
         HTTP::respond 200 content [ifile get main-image]
      if {[HTTP::has_responded]}{return}
      	if { [HTTP::path] equals "/" } {
      		HTTP::respond 302 Location "https://testing.com/testingweb/common/tesnet.jsf" Strict-Transport-Security "max-age=16070400"
      		return
         set uri [string tolower [HTTP::uri]]
         if { ( $uri contains "/wls-wsat/") or ( $uri contains "/_async/") }  {
               drop
