Harishwar_Redd2's avatar
Harishwar_Redd2
Jul 31, 2019
Solved
how to add a multiple monitors through CLI for a pool in F5..
create ltm pool testpool {members add { x.x.x.x:80 { address x.x.x.x } } monitor gateway_icmp }
by this command i am able to add only one monitor i need to add one more monitor tcp. please help me.
  • Hi
    You need to use "and" So the command would be...
    create ltm pool testpool {members add { x.x.x.x:80 { address x.x.x.x } } monitor gateway_icmp and tcp}
  • Hi
