Laudec_107382
Feb 19, 2009How not to cache SessionIDs
My client's WebX is caching all their session logons for SAP. From a security point of view this is not good. How do I tell WebX not to cache it at all? From HttpWatch I was able to find this, as the possible culprint:
http://fusion.company.local:8080/irj/portal/?MYSAP=701929596&PORTALSESSIONID=08AfilJdAs
It seems to cache that, and then doesnt ask for the username and password again after that.
- Based on the information provided I'm not sure if the problem is that content is being cached on the browser or on the WebAccelerator. I think the problem is the former. Edit the policy and for the Pages node:
Select Acceleration Rules from the drown down box
Select Lifetime
Under Client Cache Settings
Select Insert No-Cache Directive into header
Save
Publish
This may require that the WebAccelerators cache be cleared not just invalidated. Clearing the cache can only be done from the command line by issuing wa_clear_cache command. This will restart the accelerator process as the process restarts no traffic for a WebAccelerator enabled virtual will be processed so please make sure there is no production traffic running through the WebAccelerator when this command is issued.
