ertorres_290842
Sep 18, 2016How many concurrent users?
Hi All,
Is there any way I can monitor how many real time users are passing thru my F5? For example, IPs 10.10.10.1, 10.10.10.2, and 10.10.10.3 passes thru my F5, where can I see that "3" users actually pass thru my F5?
Thanks!
- Vijay_E
Cirrus
This devcentral link should answer your question.
- stan_piron
Cumulonimbus
an IP is not a user, you can have multiple users behind the same IP address.
you can list all connection with command :
tmsh show sys connectionswith this command, and sub commands (to filter client IP, server IP, protocol, ...) you can use linux commands:
tmsh show sys connection | awk -F "[ :]" '{print $1}' | sort -u | wc -l
