How does LTM_VE supports multi-tenancy?
I have an Openstack controller connecting with LTM_VE in my lab environment, they can communicate after f5-lbaas-driver and f5-bigip-lbaas-agent installed.
I have read some documents about VE from this site, and I suppose that LTM_VE is able to support multi-tenancy within Openstack system. The key configuration must be "partition / path" in VE, "f5_route_domain_strictness" "f5_common_external_networks" in /etc/neutron/f5-bigip-lbaas-agent.ini, but I cannot explain how does it works.
I don't know is it clear enough what I describe, If you know something about this, please reply the question and we can do some further conversation on this.
Thanks.
- amolari
I think what you're talking about is
route domains Which is like vrf
administrative partitions which are like configuration views
