Eddy_161863's avatar
Eddy_161863
May 04, 2016
how does IMAP health check works?
I am using advanced monitoring for IMAP and health check is failing. Since we do not define send and receive strings in IMAP health check, what information it looks for once it login to the CAS server with the username and password provided in the health check?
Also, TO use advanced monitoring, is it a requirement to offload the SSL on f5? Because for my config, I'm not doing SSL offloading or SSL bridging.
Thanks in advance for your help.
  • The IMAP monitor speaks the IMAP protocol, not IMAPS (IMAP over SSL). It also does not support STARTTLS, so it can not change to SSL after connecting to port 143.
    If your pool members are on port 443 then you can override that port on the monitor and force it to use 143 by setting the 'alias service port' advanced field of the monitor definition. Note that this field can only be set when creating a monitor, and can't be modified after that.
    Check to see if they are listening on port 143, and whether they accept plaintext authentication. In my lab, the pool member is 172.126.218.10 and the test imap account has a username of 'imap', and a password of 'imap':
    (bigip)  telnet 172.16.218.10 143
    Trying 172.16.218.10...
    Connected to 172.16.218.10.
    Escape character is '^]'.
    * OK [CAPABILITY IMAP4rev1 LITERAL+ SASL-IR LOGIN-REFERRALS ID ENABLE IDLE STARTTLS AUTH=PLAIN] Dovecot ready.
    1 LOGIN imap imap
    1 OK [CAPABILITY IMAP4rev1 LITERAL+ SASL-IR LOGIN-REFERRALS ID ENABLE IDLE SORT SORT=DISPLAY THREAD=REFERENCES THREAD=REFS MULTIAPPEND UNSELECT CHILDREN NAMESPACE UIDPLUS LIST-EXTENDED I18NLEVEL=1 CONDSTORE QRESYNC ESEARCH ESORT SEARCHRES WITHIN CONTEXT=SEARCH LIST-STATUS] Logged in
    2 LOGOUT
    * BYE Logging out
    2 OK Logout completed.
    Connection closed by foreign host.
    You mention 'advanced monitoring', which makes me think you're using the Exchange iApp, but then you say you're not using SSL Bridging, or SSL offload, which are the only two options in the iApp template. Are you load balancing SSL traffic, and have manually created an imap monitor for the pool ?
    I suggest you enable the 'Debug' option under advanced options in the monitor, and then review the log file in /var/log/monitors/Common__.log to see exactly what it is trying to do. It may be that port 143 is listening, but does not allow plain text logins (which Exchange prohibits by default), and the imap monitor can only perform plain text authentication.
    For reference, I've included a sample log file showing a successful check.
    (bigip)  tail -f /var/log/monitors/Common_imap_monitor-Common_172.16.218.10-143.log
    05:33:22.879445:(_Tcl /Common/imap_monitor): ************ Debugging session begins,
    Environment variables:
    05:33:22.879538:(_Tcl /Common/imap_monitor): ha_state active
    05:33:22.879554:(_Tcl /Common/imap_monitor): sw_product BIG-IP
    05:33:22.879563:(_Tcl /Common/imap_monitor): bigd_version 12.0.0.0.0.606
    05:33:22.879572:(_Tcl /Common/imap_monitor): pointerSize 4
    05:33:22.879580:(_Tcl /Common/imap_monitor): cluster_primary false
    05:33:22.879588:(_Tcl /Common/imap_monitor): slot_id 0
    05:33:22.879597:(_Tcl /Common/imap_monitor): wordSize 4
    05:33:22.879605:(_Tcl /Common/imap_monitor): byteOrder littleEndian
    05:33:22.879613:(_Tcl /Common/imap_monitor): osVersion 2.6.32-431.56.1.el6.f5.x86_64
    05:33:22.879622:(_Tcl /Common/imap_monitor): os Linux
    05:33:22.879630:(_Tcl /Common/imap_monitor): platform unix
    05:33:22.879638:(_Tcl /Common/imap_monitor): machine x86_64
    05:33:22.879708:(_Tcl /Common/imap_monitor): user root
    05:33:22.879719:(_Tcl /Common/imap_monitor): hostname ltm-1200-211.local
    05:33:22.879764:(_Tcl /Common/imap_monitor): ::monitor::type imap
    05:33:22.879839:(_Tcl /Common/imap_monitor): ::monitor::password imap
    05:33:22.879851:(_Tcl /Common/imap_monitor): ::monitor::url imap://172.16.218.10:143
    05:33:22.879861:(_Tcl /Common/imap_monitor): ::monitor::folder INBOX
    05:33:22.879870:(_Tcl /Common/imap_monitor): ::monitor::reverse 0
    05:33:22.879881:(_Tcl /Common/imap_monitor): ::monitor::interval 10
    05:33:22.879890:(_Tcl /Common/imap_monitor): ::monitor::node_ip 172.16.218.10
    05:33:22.879900:(_Tcl /Common/imap_monitor): ::monitor::route_domain 0
    05:33:22.879909:(_Tcl /Common/imap_monitor): ::monitor::debug yes
    05:33:22.879917:(_Tcl /Common/imap_monitor): ::monitor::username imap
    05:33:22.879926:(_Tcl /Common/imap_monitor): ::monitor::name /Common/imap_monitor
    05:33:22.879936:(_Tcl /Common/imap_monitor): ::monitor::node_port 143
    05:33:22.879944:(_Tcl /Common/imap_monitor): ::monitor::node_name /Common/172.16.218.10
    05:33:22.879953:(_Tcl /Common/imap_monitor): ::monitor::is_ip_v6 0
    05:33:22.879963:(_Tcl /Common/imap_monitor): ::monitor::timeout 31
    05:33:22.880078:(_Tcl /Common/imap_monitor): URL: imap://172.16.218.10:143/INBOX Options: -username "imap" -password "imap" -timeout 9 -connecttimeout 5 -writeproc write_to_debug -verbose 1 -debugproc verbose_write
    05:33:22.880094:(_Tcl /Common/imap_monitor): Connection Log:
    05:33:22.880476:(_Tcl /Common/imap_monitor): timeout on name lookup is not supported
    05:33:22.880516:(_Tcl /Common/imap_monitor): About to connect() to 172.16.218.10 port 143 (0)
    05:33:22.880552:(_Tcl /Common/imap_monitor):   Trying 172.16.218.10...
    05:33:22.884341:(_Tcl /Common/imap_monitor): connected
    05:33:22.884379:(_Tcl /Common/imap_monitor): Connected to 172.16.218.10 (172.16.218.10) port 143 (0)
    05:33:22.896946:(_Tcl /Common/imap_monitor): * OK [CAPABILITY IMAP4rev1 LITERAL+ SASL-IR LOGIN-REFERRALS ID ENABLE IDLE STARTTLS AUTH=PLAIN] Dovecot ready.
    05:33:22.897017:(_Tcl /Common/imap_monitor): B LOGIN imap imap
    05:33:22.927866:(_Tcl /Common/imap_monitor): B OK [CAPABILITY IMAP4rev1 LITERAL+ SASL-IR LOGIN-REFERRALS ID ENABLE IDLE SORT SORT=DISPLAY THREAD=REFERENCES THREAD=REFS MULTIAPPEND UNSELECT CHILDREN NAMESPACE UIDPLUS LIST-EXTENDED I18NLEVEL=1 CONDSTORE QRESYNC ESEARCH ESORT SEARCHRES WITHIN CONTEXT=SEARCH LIST-STATUS] Logged in
    05:33:22.927945:(_Tcl /Common/imap_monitor): C SELECT INBOX
    05:33:22.932823:(_Tcl /Common/imap_monitor): * FLAGS (\Answered \Flagged \Deleted \Seen \Draft)
    05:33:22.932851:(_Tcl /Common/imap_monitor): * OK [PERMANENTFLAGS (\Answered \Flagged \Deleted \Seen \Draft \*)] Flags permitted.
    05:33:22.932859:(_Tcl /Common/imap_monitor): * 1 EXISTS
    05:33:22.932866:(_Tcl /Common/imap_monitor): * 0 RECENT
    05:33:22.932873:(_Tcl /Common/imap_monitor): * OK [UIDVALIDITY 1462451573] UIDs valid
    05:33:22.932880:(_Tcl /Common/imap_monitor): * OK [UIDNEXT 2] Predicted next UID
    05:33:22.932887:(_Tcl /Common/imap_monitor): * OK [HIGHESTMODSEQ 1] Highest
    05:33:22.932893:(_Tcl /Common/imap_monitor): C OK [READ-WRITE] Select completed.
    05:33:22.932914:(_Tcl /Common/imap_monitor): D FETCH 1 BODY[TEXT]
    05:33:22.937804:(_Tcl /Common/imap_monitor): * 1 FETCH (BODY[TEXT] {34}
    05:33:22.937823:(_Tcl /Common/imap_monitor): Found 34 bytes to download
    05:33:22.937841:(_Tcl /Common/imap_monitor):
    sdaf
    sf
    sdf
    sdfsdf
    05:33:22.937850:(_Tcl /Common/imap_monitor): Filesize left: 0
    05:33:22.937862:(_Tcl /Common/imap_monitor): Connection 0 to host 172.16.218.10 left intact
    05:33:22.937886:(_Tcl /Common/imap_monitor): A LOGOUT
    05:33:22.942813:(_Tcl /Common/imap_monitor): )
    05:33:22.942831:(_Tcl /Common/imap_monitor): D OK Fetch completed.
    05:33:22.942844:(_Tcl /Common/imap_monitor): * BYE Logging out
    05:33:22.942851:(_Tcl /Common/imap_monitor): A OK Logout completed.
    05:33:22.942859:(_Tcl /Common/imap_monitor): Closing connection 0
    As you can see, the imap monitor connects, authenticates using plain text, selects the inbox, and fetches the first message from it. If any of those steps fail, the monitor gets marked down.
  • thank you!!
    so I did troubleshoot and looks like server side doesn't accept plaintext authentication. I will try to test it with plaintext enabled and let you know the results.
    My another question, how I can achieve the same for secure IMAP? I'm not using iapp template and all config is manual. I want to define username and password to login to the server. should I be using IMAP or HTTPS monitor?
    • IanB's avatar
      IanB
      BigIP does not have a built-in IMAPS monitor type. You could create an external shell script that would make use of 'openssl s_client' to create an SSL connection, and then run its own IMAP check, but you would have to write this yourself, or find one already written here on devcentral (I haven't looked to see if there are any). An HTTPS monitor would not work, as it speaks HTTP over SSL, and you need to speak IMAP over SSL.
  • For your second question, HTTPS monitor would be the possible option. I would be glad to have second opinions here
  • Hi Eddy, I have the same issue with monitoring IMAP/POP3 over SSL, have you resolved with a script?
    Thank you for your time.
