Simon_Waters_13's avatar
Simon_Waters_13
Jun 24, 2014
How do I tell if fix for ID453531 made it into 11.5.1.3.0.131?
Whilst I wait for support paper work to be sorted.
I can't see a reference in the Release notes to 453531, so it seems likely it isn't fixed.
If so I'll need an engineering hotfix for each release until it is incorporated (if ever), presumably that also requires support.
  • Unfortunately, it is not in the official hotfix rollup just yet. If you need this addressed before HF4 is released, you can ask for an engineering hotfix or you can also run 11.4.1, which is not affected by this bug.
  • I suspect we'll need a hotfix, as there seem to be some mcpd issues with APM still, and I was assuming probably better to upgrade than to fix.
    • Simon_Waters_13's avatar
      Simon_Waters_13
      Sorry better to upgrade, than to investigate when there are known issues already fixed.
