How do I adjust the logging level on LTMs/GTMs
So I would like to adjust the default minimum logging level that my LTMs/GTMs write to their local/remote logs. I did some poking around and discovered the bigpipe command, but unfortunately (or fortunately I need the tmsh command), so I tried to find an equivalent, but I am having some difficulty finding the exact command structure. So right now I am at the default of "informational" logging and I wanted to bump that up to "warning" (my local logs are becoming quite full on things that I don't readily need).
- Michael_Jenkins
SOL5532 should be able to help you with modifying the logging levels.
- David__Pasch
Altostratus
Tom, What is the bigpipe command you are trying to find a tmsh equivilant for?
Do you have GUI(browser) access?
There you can go to System -> Logs -> Configuration -> Options and set the level of the logging. If I understand you correctly.
Hope it helps!
David "Cupcakes" Pasch
- Mahmoud_Eldeeb_
SOL5532: Configuring the level of information logged for TMM-specific events https://support.f5.com/kb/en-us/solutions/public/5000/500/sol5532.html
- Tom_Ebert
Ah okay, I think that I did not understand the GUI then. I thought I was changing what level those events would be reported as. I will play with this a bit.
Thanks for your help with this!
Tom
