Asif_Thobhani_7's avatar
Asif_Thobhani_7
Jun 11, 2008
How can I read the persistence profile settings using PROFILE::persist
Can someone please help with how to use the PROFILE::persist command?
From within my iRule, I want to find out what's the name of the cookie that's been used for persistence (cookie insert).
Here is what I have so far:
profile persist my_cookie_profile {
defaults from cookie
mode cookie
cookie mode insert
cookie name my_cookie
when CLIENT_ACCEPTED {
if { [PROFILE::exists clientssl] == 1} {
log local0. "client SSL profile enabled on virtual server"
if { [PROFILE::exists persist cookie] == 1} {
log local0. "persist cookie profile enabled on virtual server"
set perCookie [PROFILE::persist cookie ?] ===> What's the right command syntax here?
  • Thanks Aaron for your reply...
    We do have a custom cookie name and I need to read the name from within iRule, so that I can encrypt/decrypt the cookie....Since we have a generic rule, used by different projects (each having their own cookie name), we would like to read it from the PROFILE command.
    Anyone knows the right syntax for PROFILE:: commands? Any examples on how to use it would be really appreciate it. Wiki documentation is really incomplete.
    Thanks,
    -Asif
  • I think I finally figured out how to use the PROFILE::persist commands (after some trial and error)...
    Here is what I have along with the output
    mode cookie
    cookie mode insert
    cookie name MY_PERSIST_COOKIE
    cookie expiration 0d 00:10:00
    set cert [PROFILE::clientssl cert]
    log local0. "clientssl certificate is: $cert"
    set key [PROFILE::clientssl key]
    log local0. "clientssl key is: $key"
    set cookie_profile_name [PROFILE::persist mode cookie name]
    log local0. "persist cookie profile name is: $cookie_profile_name"
    set persist_cookie_name [PROFILE::persist mode cookie cookie_name]
    log local0. "Name of the cookie used for persistence is: $persist_cookie_name"
    set cookie_expiration [PROFILE::persist mode cookie cookie_expiration]
    log local0. "Cookie expiration is set for: $cookie_expiration"
    ***********output**************
    Jun 18 00:30:34 tmm tmm[28049]: Rule read_PROFILE_Commands : client SSL profile enabled on virtual server
    Jun 18 00:30:34 tmm tmm[28049]: Rule read_PROFILE_Commands : clientssl certificate is: dev-crm.crt
    Jun 18 00:30:34 tmm tmm[28049]: Rule read_PROFILE_Commands : clientssl key is: dev-crm.key
    Jun 18 00:30:34 tmm tmm[28049]: Rule read_PROFILE_Commands : persist cookie profile enabled on virtual server
    Jun 18 00:30:34 tmm tmm[28049]: Rule read_PROFILE_Commands : persist cookie profile name is: my_cookie_profile
    Jun 18 00:30:34 tmm tmm[28049]: Rule read_PROFILE_Commands : Name of the cookie used for persistence is: MY_PERSIST_COOKIE
    Jun 18 00:30:34 tmm tmm[28049]: Rule read_PROFILE_Commands : Cookie expiration is set for: 600
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    I'm glad to hear things are working better for you now. Let us know if you've got any more questions to work through.
    Colin
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    I talked to PD about getting some details to update the PROFILE:: command pages, and they have agreed to work on it with us in the near term.
    I can't promise anything today, but stay tuned for updates. I will blog about it when we start getting it filled in.
    /deb
  • hoolio's avatar
    hoolio
    Hi iRuleYou,
    Is there something in particular you're looking for? If so and no one here can help, you might try opening a case with F5 Support asking them to provide details an update the wiki page. I got a good response for the PROFILE::http options from them.
    Aaron
