pantheon_251128
Mar 04, 2016How can i configure the BIG-IP LTM to load balance FTPS traffic using passthrough encryption.
Not SOL9347 ,It doesn't apply to BIG-IP LTM 9.4.8
- Chris_Grant
Employee
While SOL9347 isn't directly applicable, the same principles apply. What are you getting hung up on when trying to follow the SOL in version 9? Also version 9 has not had a security patch in nearly 4 years, so be aware.
