Hotfix installation forced VCMP into offline mode
A VCMP running 11.4.1 HF9 was upgraded to HF10. After reboot it went automatically in offline mode. This is the only VCMP on the blade and in the cluster.
What can be wrong?
- tatmotiv
If I understand you correctly, the vCMP guest now is listed as offline (e.g. in tmsh show vcmp guest all)?
If so, what's its requested state and what happens if you change the requested state to something else than 'deployed' and then back to 'deployed'?
Do you see any interesting log messages?
BTW: Did you perform the HF install on the vCMP guest or on the vCMP host (or both)?
