Srini_87152
May 03, 2011historical connection reports
I would like know how to get historical connection reports for pool member.
If we take example like below,its give current connection report of the pool.
[root@F5:Active] ~ b pool pool_sso_23389 |grep conn POOL pool_essostgldap_23389 LB METHOD member least conn MIN/CUR ACTIVE MEMBERS: 0/2 | conns (cur, max, limit, tot) = (7, 103, 0, 2.576M) | | conns (cur, max, limit, tot) = (6, 51, 0, 1.347M) | conns (cur, max, limit, tot) = (1, 52, 0, 1.229M)
This connection ,i need historical data same with time period wize[like take every 30 min]
Regards,
Srinivas
- hoolio
Hi Srinivas,
Currently, LTM does not log this type of historical data locally. You could look at Enterprise Manager for a non-free solution. Or others have had success with Cacti. For more info on EM, you can check f5.com. Try searching the forums here for details on Cacti.
Aaron - Srini_87152
Hi Aron,
I belive there should be option with Cron script or SNMP .i have raised case with F5 waiting for update.
if any body have option,please replay.
Regards,
Srinivas
