Pieter_72260
Feb 07, 2013High speed logging and round robin load balancing issues
We have a couple of F5 servers that have an iRule that uses HSL to send log messages to a pool of remote rsyslog daemons.
The rsyslog daemons are added to one pool, and the pool is con...
nitass
Employee
Feb 12, 2013i did test on my 10.2.4 unit and got the same issue (i.e. hsl log is sent to only one pool member. additionally, only 3-way handshake is done). i think it could be a bug.
have you opened a support case? if not yet, would you mind logging a case to verify?
