Pieter_72260
Feb 07, 2013High speed logging and round robin load balancing issues
We have a couple of F5 servers that have an iRule that uses HSL to send log messages to a pool of remote rsyslog daemons.
The rsyslog daemons are added to one pool, and the pool is con...
What_Lies_Bene1
Feb 08, 2013The persistence method you mention is for HTTP traffic using the VS, not the HSL traffic. The HSL Pool configuration looks good. Do you know if the F5 is opening multiple connections or just one?
