Pieter_72260
Feb 07, 2013High speed logging and round robin load balancing issues
We have a couple of F5 servers that have an iRule that uses HSL to send log messages to a pool of remote rsyslog daemons.
The rsyslog daemons are added to one pool, and the pool is con...
Pieter_72260
Feb 07, 2013Hi Aron,
Below is the pool config:
ltm pool hsl_pool {
members {
10.197.15.45:514 {
session monitor-enabled
10.197.15.46:514 {
monitor tcp
Once colleague thinks it might have something to do with the persistency settings that are used in the irule:
when HTTP_REQUEST priority 100 {
if { "POST" eq [HTTP::method] } {
persist none
persist carp [HTTP::uri]
Thanks in advance,
Pieter
