Pieter_72260
Feb 07, 2013High speed logging and round robin load balancing issues
We have a couple of F5 servers that have an iRule that uses HSL to send log messages to a pool of remote rsyslog daemons.
The rsyslog daemons are added to one pool, and the pool is con...
hoolio
Feb 07, 2013Hi Pieter,
Can you post the HSL pool config using 'tmsh list ltm pool hsl_pool' and reply with the anonymized output?
Thanks, Aaron
