Maneesh_72711's avatar
Maneesh_72711
Apr 02, 2017
High CPU alert from LTM running on Viprion Chassis also has asm Enabled.
I have an issue everyday around 04:37 GMT I get an alert from LTM running on a Viprion chassis. For HIGH CPU, by the time I login to the device to check the CPU it has come down to 12-13%.
Sys::System CPU Information System CPU Usage(%) Current Average Max(since 04/03/17 03:25:22)
Utilization 12 14 100
In one of the old thread I saw someone mentioned this could be due to scheduled SYNC between the device and since this box also has ASM running on it it could be related to that as it uses JAVA as well to SYNC.
  • Can anyone help me find where the timing is defined when to AutoSYNC the configs ?
