Tim_18689's avatar
Tim_18689
Icon for Cirrus rankCirrus
Jan 18, 2013
Here is a basic example of pool creation using bigsuds
I am a novice at python and it was difficult for me to figure out the syntax for creating a pool using bigsuds. The examples on code share were a little advanced to help me when I was just starting out so I am posting very basic examples here that can be used to figure out the syntax when creating more advanced scripts using bigsuds.
This will create a pool, set a monitor, enable Priority Group activation, and set the priority group value for the members.
!/usr/bin/python
import bigsuds
set target system and supply login info
b = bigsuds.BIGIP(
hostname = '10.3.214.70',
username = 'admin',
password = 'admin',
make members
b.LocalLB.Pool.create_v2(
pool_names = ['fake2'],
lb_methods = ['LB_METHOD_ROUND_ROBIN'],
members = [[
{'address': '10.1.212.233', 'port': '80'},
{'address': '10.1.212.234', 'port': '80'},
{'address': '10.1.212.235', 'port': '80'},
{'address': '10.1.212.236', 'port': '80'},
{'address': '10.1.212.237', 'port': '80'}
adding monitor to pool
b.LocalLB.Pool.set_monitor_association(
monitor_associations = [{'monitor_rule': {'monitor_templates': ['/Common/http'], 'quorum': 0,'type': 'MONITOR_RULE_TYPE_SINGLE'},'pool_name': 'fake2'}]
adding "Priority Group Activation" value
b.LocalLB.Pool.set_minimum_active_member(
values = ['2']
setting the priority group membership for pool members
b.LocalLB.Pool.set_member_priority(
members = [[
priorities = [[10, 10, 10, 5, 5 ]]
