souravkayal_287's avatar
souravkayal_287
8 years ago
Help with the stream /http/https rule
when RULE_INIT { unset -nocomplain static::rewrite_table array set static::rewrite_table { "; "; "; "; } set static::rewrite_table_map [list] set static::rewrite_table_stream [list] foreach item [array names static::rewrite_table] { lappend static::rewrite_table_map $static::rewrite_table($item)/ $item/ $static::rewrite_table($item) $item/ lappend static::rewrite_table_stream "@$static::rewrite_table($item)/@$item/@" } log local0. $static::rewrite_table_map log local0. $static::rewrite_table_stream create stream commands in variables to run them only id stream profile is enabled set static::stream_disable "STREAM::disable" set static::stream_enable "STREAM::enable" change stream expression to convert current site response to relative URI. set static::stream_expression "STREAM::expression [string map \"\$req_proto://\$req_host/ /\" \$static::rewrite_table_stream]" }
when CLIENT_ACCEPTED { set default protocol to http. change it to https if clientssl profile is assigned to the VS. if { [PROFILE::exists clientssl] == 1} { set req_proto "https" } else { set req_proto "http" } set stream_profile_enabled [PROFILE::exists stream] }
when HTTP_REQUEST { Capture request hostname set req_host [HTTP::host] if {$stream_profile_enabled} { Disable the stream filter for all requests eval $static::stream_disable
     LTM does not uncompress response content, so if the webserver has compression enabled
     we must prevent the server from send us a compressed response by changing the request
     header that indicates client support for compression (on our LTM client-side we can re-
     apply compression before the response goes across the Internet)
    HTTP::header remove "Accept-Encoding"
when HTTP_RESPONSE { if { [HTTP::status] matches "30?"} { This is a 302 redirect with a absolute Location URI HTTP::header replace Location [string map [string map "$req_proto://$req_host/ /" $static::rewrite_table_map] [HTTP::header Location]] } elseif {[HTTP::header value Content-Type] starts_with "text"} { Apply stream expression stored in RULE_INIT event if {$stream_profile_enabled} { eval $static::stream_expression
         Enable the stream filter for this response only
        eval $static::stream_enable
SO i have this rule and it was working fine. But we set up another Dr environmnent with a differnet url but same application logic and its not working anymore for the http--> https on 8443. I think its because of the global variables in rule_init command. Can someone help please to rectify
  • Suggest you edit your post, copy and paste a fresh iRule. Highlight each iRule event and its associated code then press TAB. This will then format it correctly as code. Before each event, a one liner on what its doing would be very helpful.
  • when RULE_INIT { unset -nocomplain static::rewrite_table array set static::rewrite_table { "; "; } set static::rewrite_table_map [list] set static::rewrite_table_stream [list] foreach item [array names static::rewrite_table] { lappend static::rewrite_table_map $static::rewrite_table($item)/ $item/ $static::rewrite_table($item) $item/ lappend static::rewrite_table_stream "@$static::rewrite_table($item)/@$item/@" } log local0. $static::rewrite_table_map log local0. $static::rewrite_table_stream create stream commands in variables to run them only id stream profile is enabled set static::stream_disable "STREAM::disable" set static::stream_enable "STREAM::enable" change stream expression to convert current site response to relative URI. set static::stream_expression "STREAM::expression [string map \"\$req_proto://\$req_host/ /\" \$static::rewrite_table_stream]" }
