Bill_Kehn_27007's avatar
Bill_Kehn_27007
Oct 14, 2017
Help with Passing Basic http authentication username/password in APM policy.
Hello,
I am trying to accomplish something rather basic in APM and seem to be stuck. I want to use a separate credential against APM internal DB and then map a generic credential to be used against a basic authentication challenge presented by the back end server after successful policy.
Right now I have a logon page for testing but in the end it will be clientless. My logon page and auth against the APM DB works just fine. The problem is I am getting the 401 from the server right after that instead of passing a general credential (configured in SSO Configurations -> Basic HTTP). I am sure I am missing something simple.
My policy looks like this:
My SSO config looks like this:
Do I need a credential mapping in my policy as well?
Here is the APM log:
Thank you! Bill
  • Well, I added an irule like this and it seems to work:
    when HTTP_REQUEST { set logindata [b64encode "basic_user:basic_pass"] log local0. "FOUND A REQUEST, SETTING AUTH $logindata" HTTP::header replace Authorization "Basic $logindata" }
    I was hoping there was some way within APM itself to do this without an irule.
    -Bill
  • If you want to use alternate credentials for the backend then you would create an variable assign object to rewrite the sso variables after the LocalDB auth.
    Variable Assign Agent
    session.sso.token.last.username = string "myuser"
    session.sso.token.last.password = string "mypass"
    Delete those headers you added to the SSO profile.
