Help with maintenance page iRule needed
Hi all, I am working on migration of static maintenance page from stand alone web server to Big-IP. I am sucessfully using iRule below to compile a static page using content uploaded to iFile.
switch [HTTP::uri] {
"/main.css" {
HTTP::respond 200 content [ifile get main.css] "Content-Type" "text/css"
"/image001.jpg" {
HTTP::respond 200 content [ifile get image002.jpg] "Content-Type" "image/jpg"
"/home_bkgrd.gif" {
HTTP::respond 200 content [ifile get home_bkgrd.gif] "Content-Type" "image/gif"
"/logo.gif" {
HTTP::respond 200 content [ifile get logo.gif] "Content-Type" "image/gif"
"/corporatenav_bkgrd.gif" {
HTTP::respond 200 content [ifile get corporatenav_bkgrd.gif] "Content-Type" "image/gif"
"/main_bkgrd.gif" {
HTTP::respond 200 content [ifile get main_bkgrd.gif] "Content-Type" "image/gif"
"/logo_print.gif" {
HTTP::respond 200 content [ifile get logo_print.gif] "Content-Type" "image/gif"
default {
HTTP::respond 200 content [ifile get index.htm] "Content-Type" "text/html"
I have also uploaded a alternative version of index.htm (index2.htm) that contains slightly different maintenance page message. Challenge is that I need to alternate between index.htm and index2.htm depending on request URI. So per say when request URI eq /companyA index2.htm is served but for any other URI index.htm is served by iRule. Any help is greatly appreciated.
you can change some part of your code as below :
default { if { [HTTP::path] eq "/companyA" } { HTTP::respond 200 content [ifile get index2.htm] "Content-Type" "text/html" } else { HTTP::respond 200 content [ifile get index.htm] "Content-Type" "text/html" } }If you have several uri to include, you can use a datagroupv:
default { if { [class match [HTTP::path] URI_DATAGROUP] } { HTTP::respond 200 content [ifile get index2.htm] "Content-Type" "text/html" } else { HTTP::respond 200 content [ifile get index.htm] "Content-Type" "text/html" } }
