Help with IRule
I am having issues with my iRule.
Running code BIG-IP 10.2.1 Build 297.0 Final
iRule
if { not ([matchclass [IP::client_addr] equals $::SS_CMS_Nets]) and ([matchclass [string tolower [HTTP::uri]] contains $::SS_CMS_URLs]) } {
HTTP::redirect "http://siteroot.com"
DataGroups
SS_CMS_NETS
192.168.100.0/24
SS_CMS_URLS
/cms-admin
What I am trying to achieve is to only allow requests to http://siteroot.com/cms-admin/ to be served to clients coming from the 192.168.100.0/24 subnet. All other clients need to be redirected back to http://siteroot.com/
So far all that happens is all clients irrespective of IP address get directed back to http://siteroot.com
Can someone please help figure out what I am doing wrong here?
- Michael_Yates
Hi esexon,
You could change your logic a little bit and save yourself some unnecessary processing.
Only trigger the verification if the URI contains "cms-admin". If it does, then check to see if they are authorized.
Here are two different ways of doing it....when HTTP_REQUEST { if { [string tolower [HTTP::uri]] contains "/cms-admin" } { If URI matches verify that the Client has access if { !([class match [IP::client_addr] equals AllowedNetworkList ]) } { If they do NOT have access, do this: HTTP::redirect "http://www.google.com" } } } when HTTP_REQUEST { if { [string tolower [HTTP::uri]] contains "/cms-admin" } { If URI matches verify that the Client has access if { [class match [IP::client_addr] equals BlockNetworkList] } { If they DO have access, do this: HTTP::redirect "http://www.google.com" } } }
Hope this helps. - Michael_Yates
Oh,
In v10.x.x you should start to use "class match" instead of the v9.x.x command "matchclass".
You can ignore the "BlockedNetworkList" Data Group Name in the second example (that is the name of the Data Group that I reused on my system and I forgot to rename it to correspond to the first example....tired to correct it but it wouldn't let me). - esexon_27963
Hi, makes sense but for some reason it still doesn't work.
It always redirects me even though my machine is one of the AllowedNetworksList IP Addresses instead of sening me to "/cms-admin"
Is there anything else I can try,
Thanks again for the quick reply. - esexon_27963
This is the rule I have in place.
if { not [class match [IP::client_addr] equals AllowedNetworkList] } {
If they DO Not have access, do this:
HTTP::redirect "/"
No matter what I do it redirects all client addresses back to the / and seems to ignore my AllowedNetworkList.
Pulling my hair out here so would appreciate any feedback
Many thanks,
Evan
